AT4 Rims on a Trail boss?
I like the looks of the 20 inch AT4 rims and was thinking of getting a set to run in the summer with street tires and save my 18 inch trail boss duratracs for the winter.
The 20 inch 275/60/20 tires are almost an inch taller than the the 275/65/18s on my trail boss. Do you need a different sized spare tire or a taller jack? I know some of the GM wheel packages come with a taller jack.
Also do the GMC use the same tpms as the Chevy? Seems obvious they would but thought I would ask.2407cceb856204f25e95b6dc39f86786.jpg
Sent from my Pixel 4 using Tapatalk
Everything will work fine the tpms will sync up fine and the tire size shouldn’t cause any negative effects
When you build a trail boss online and select the 20 inch rims it changes the spare tire from 265/70/18 to 255/80/17.
  • 3 months later...
Did you ever get these put on, if so do you have pictures?
