Wiper motor problems
35Greg
I have a 2005 Silverado 3500 wipers only work on high speed have replaced the pulse module, same issue. Replaced wiper motor with a new one, same issue. Have anyone else encounter the same problem and if so did you find out what is causing it?
Have replaced wiper motor and wiper/turn signal switch, no change motor still only works on high speed only. I can not locate a relay for the wiper motor, thinking that it might be built into the pulse module but not sure pulse module has also been changed twice.
Only thing else I can suggest is signing up for the full-service manual at a site like alldatadiy.com  It'll have the diagnostic procedure for figuring out what the problem could be.
