97 K1500 electrical problem
I've got a '97 K1500 with a weird electrical problem. If I leave the battery connected, it goes completely dead in 2-3 days. I disconnected the negative cable at the battery & I'm getting 10.4 volts through it. I started pulling the underhood fuses & when I pull the 50 amp battery fuse & 50 amp lighting fuse together there's no voltage. I tried just one at a time & still have 10.4 volts. I have traced wires out & haven't been able to find anything. I was wondering if it could be something in the fuse box itself shorting or if anybody has any ideas. Thank you
