I have a 2017 crew cab. I have replaced the evap solenoid and canister but the code will not go away. Can it be a wiring issue? What exactly would I need to get to replace the wiring if it is that?
Ok. Lets talk about this before we throw any more parts at it. Why you put a canister on it for a Vent control circuit code is already a mystery. If you want to throw money away I will give you my paypal! LOL
Ok, So the P0449 is a Vent Solenoid Valve Control Circuit code.
What this means is the ECM sees that the vent control circuit is open.
Lucky for you this is a SIMPLE circuit.
There are 2 wires coming to the vent solenoid.
You have a Red/Green wire. This wire should have power on it... ALL THE TIME. It is Powered by fuse 67 at the underhood fuse block. Go ahead and give that a check and make sure the fuse is good.
Once you have tested it and made sure the fuse is good, Disconnect the vent valve itself and test the red/green wire WITHOUT cramming your test-light in the terminal and screwing it up. Just a little touch will suffice.. just the tip... lol. If your test light shines bright like a diamond... That circuit is good.
Next we go to the Control circuit. The control circuit for 99% of everything GM is a ground circuit. In order to test this circuit you really need to have access to a inexpensive scanner that will control the solenoid open and closed...  and for only 34.98 + the coupon that Amazon gives you saving you an extra 10% you can have this ( https://amzn.to/3a7OWcx ) practically basic paperweight scanner that will command your vent solenoid open and closed, clear codes, and illuminate your vehicle on a dark stormy night just long enough to kill your battery and leave you stranded on the side of the road.
If you decide to purchase this gem, while the vehicle is in the run position. Command the circuit on and off and using your test light like a precision penile enlargement surgeon, insert just the tippy tip ohh so softly in the end of terminal 1 White with the other end connected to power, and see if the test light flashes like the lights of a Christmas tree.
Now, if you are broke or like me so tight with your money, you squeak when you walk (tight butt cheeks joke... I workout.) We can test the circuit the hard way.
To do this you need to disconnect connector 1 of your engine control module. with a piece of 18 gauge wire, strip the end of it and twist the wires tighter than... well my butt cheeks again and insert it (just the tip) into terminal 56 White wire of connector 1. With other end of your extremely long 18 gauge wire... stretch it across the engine and attach it to the positive post of your battery. What this will do is send power down that circuit and you can test the continuity and the amount of amperage that wire will allow by testing it at terminal 1 White wire of at the vent solenoid. If it lights up your test light... Then that circuit is good as well.
At this point if both circuits test good. You either have a faulty part... again... or a faulty ECM.
All joking aside... this is an easy test... stop throwing money away.
Love you, Mean it!
I was just going through the steps I found on google lol. I will give this a try!! Thank you so very much for all the information! I really appreciate it. Love you man ❤️
  • 4 years later...
4 hours ago, Leftside said:
How did this work for you I’m having similar issues replaced both parts as well and still have a check engine light coming back on.
EVAP smoke test and find the leak.  Stop shotgunning parts at it.
    • I just brought home a 2020 GMC 1500 Denali.  She has 53K miles on her and I want to change out the fluids over the next few weeks.  I see the diff covers don't have drain plugs.  Any suggestions where I can pick up front and rear diff covers with drain plugs?   Thanks,   Bob
    • Well, the dealership got the compressor and installed it. Air at the vents seems nice and cold as it should be. The service manager said the repair has a two year warranty and unlimited mileage. Hopefully I don't have to use it. The dealership i went to was one where I bought my 2014 half ton silverado. In 10 years and 168k miles on the truck anything I needed done and two small recalls they were always very good to me. Not a huge dealer either. I think they treat people well because they want you to come back. I have dealt with a different dealer that was too big to care about an individual. Just my two cents.
    • Hi All, I operate my 2021 3500 SLT most of the time with the tailgate off and in a crate because I have a slide-in camper. However, at least once a year, I take the camper off and put the tailgate back on. Recently I installed the tailgate, but had a hard time getting the connector bail to swing to the fully latched position. The connector seems to fully seat, and everything works, but the bail doesn’t swing to fully latched position.  It swings almost there but stops and I am afraid to push it any harder.    Does anyone have any advice on cleaning or lubrication or anything else I should be doing?  i know how to properly operate the connector. During the time the tailgate and connector are off, i have a double plastic bag over the truck connector secured with rubber bands to keep it clean, but it still had some dust in it this time when I blew it out with compressed air. I didn’t want to spray it with anything other than air without doing some research. Thanks.
    • There are a lot of spammer's that do that, quote something and add some commentary to make it seem legit, but modify the quoted text a bunch making sure when posted it's long enough to be "click to expand", and either immediately insert a spam link, or come back after some time and edit it to add the spam link.
    • Hello @jaszr2 Do you have a link for the item? I put a replacement bumper on my truck and consequently had to relocate the shutters. I studied on them a while, and figured if you left a couple key blades, you could get most of the airflow with probably no throwing codes.
