Just installed new rotors calipers pads hoses on rear.
Trying to bleed and can’t get fluid to the rear to bleed, there’s plenty of fluid and didn’t lose much when I cracked lines.
How can I get it to bleed?
On second observation I think I did bleed all fluid from rear lines, will a vacuumed pump help me get fluid back to the rears?
Yes, get a vacuum bleeder from Harbor Freight- they're inexpensive and worth having. If possible borrow a scanner from someone that can cycle the ABS module to assist in the bleeding procedure.
Maybe describe what you are doing to bleed the brakes?
You have filled the master cylinder, then you open the bleeder, and have someone press on the brake pedal, then you close the bleeder, and the person releases the brake pedal?  And when the person presses on the brake pedal, no fluid comes out?
That’s funny you should say, I looked online at Harbor Freight and they have a vac pump for $20 , thanks at least I’m thinking in the right direction.
 I tried bleeding the traditional way and only am getting a trickle of fluid at the bleeder. Pump 10 times and hold, etc, and cannot build any pressure.
We're missing something here as it shouldn't be that difficult to bleed manually. In fact, you can literally do it by gravity bleeding by leaving the bleeders open in a pinch if you're by yourself. I wouldn't recommend using the vacuum methods as while they can and do work sometimes, they also have been known to pull air past the treads of the bleeder screw and not allowing a proper bleeding of the fluid.
Yeah, that sounds like something has gone wrong somewhere (perhaps the MC ran dry?).  I doubt just using a different way to bleed the brakes will help with how the brakes work...
Bought a vacuum bleeder and I’m not getting fluid to the rear, the mc is full, but maybe I’ve drained all fluid out of rear lines?
‘Driving me nuts.
No, there isn't that much in them.  I would suggest cracking lines moving forward from the rear, and seeing where you get fluid.  But it sounds like something is wrong with your MC.
  • 2 years later...
    Tonwantonga
    Tonwantonga
  • Who's Online   4 Members, 1 Anonymous, 717 Guests (See full list)
    • What I think you're saying is there is supply here at home, and in Venezuela, and we could ease pricing if only it were favorable to do so.   Well, yes?   But that's not the current market. Supply isn't what could someday exist, if only, it's what producers are willing to produce and sell at a certain price point.   The national price of single family homes would come way down if we'd just slap together a few million homes this summer.   RAM and GPUs would get a lot cheaper if we just set up some factories to produce a bunch more and stopped using it to build out AI data centers.
    • The turn signal/multifunction switch is faulty.  I've seen a few of these go bad at work.
    • I am experiecing the same issue, I have gone in the setting and disabled rain sensing function but I am still experiencing this. Whe i use my turn signal they will redomly turn on. Sometime they stay on and others times we swipe 2 or 3 times and stop. Its super anoying, escpecially after a fresh wash. Anyone have any advice? . rain-sensing function, but I am still experiencing this issue Sometimes they stay on, and other times we swipe 2 or 3 times and stop.It's super annoying, especially after a fresh wash.When I use my turn signal, they will randomly turn on. I am experiencing the same issue. I have gone into the settings and disabled the rain sensing function, but I am still experiencing this.
    • If we actually used any significant amount of that source in the USA then I'd agree but we don't. We've had that discussion before. We drill and pump more than we use. Thing is, we sell. We export. Gas and Crude. It's more profitable so any shortage here is self inflicted and LEGAL.    I worked a gas plant that has multiple fuel sources available and I worked in the furnace and boiler plant in that facility. I'd had days we swapped fuel types four times in a twelve hour shift which isn't done on supply but on margin. Two of the fuel sources are internally generated. Tail gas and DAK, both of which are sold as well a consumed. We always had more than we needed to run the process but we chose the fuel that produced the best margin not bought at the cheapest price always. A good bit of math to that and back in the time that was done on a slide rule.     I worked the Shale Oil Semiworks of Chevron Research and CONOCO Research in Salt Lake City. That process never went into production although it was very successful. Why? Did we lack oil bearing shale? Nope. Price of crude never made the margins work. That was in the late 70's early 80's. Remember history? What was happening then was a reaction to that situation. It didn't drive it. If so then it's easy. This isn't a supply and demand thing. This is a profit and margin thing and AI rules that now.    In no refining situation that I was ever in would a bomb hitting a well anywhere in the world 'instantly' interrupt or even distress the supply. Most plants have more than a months worth of crude in the tank field and more in pumping stations. That yo-yo could play out over days, weeks and maybe months and have zero impact on plant operations. How many times has this been off and on in the last few months? These people and not stupid. These plants measure down time in hundreds of thousands of dollars per day. They are not sucking fumes or waiting on the next truckload with baited breath. Besides, as I noted, they are for the most part 'vertically integrated'. They own it from the dirt is sits in to the delivery rack and sometimes to the pump. It has a HUGE shock absorber built in. When production suffers, refining wins and when refining is winning exploration is killing. The rest of that crap in the news is a 'news cycle'. Government dipping in to reserves? Oil is stealing their milk money. There's a reason Chevron abandon Venezuela infrastructure and it had nothing to do with security of US citizens. Nationals run those plants. it has to do with MARGINS disappearing to corruption. They are in no hurry to return. Is there supply there? Oh yea. More than enough to offset what is bought in the middle east. Just isn't ???? Profitable.    We have supply. There are places in Illinois you can drive a pipe into the ground and run your homes natural gas furnace on it.    A refinery fire will gum up the supply works but not a localized war where the market is using a limited supply from. Now Europe, that's something other....
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
