Dgjones Posted March 8, 2020 Posted March 8, 2020 My 2012 traverse ac is cooling on passenger side and rear but not drivers side, I have changed blend actuator, took fuse out to reset, unhooked battery because this all started after battery replacement, nothing works, please help.
tlaw91 Posted March 9, 2020 Posted March 9, 2020 Blend door actuator does not control left/right function. You need a driver temp door actuator. And disconnecting a fuse does not calibrate it you need a scan tool.Sent from my iPhone using Tapatalk
Dgjones Posted March 13, 2020 Author Posted March 13, 2020 On 3/9/2020 at 10:32 AM, tlaw91 said: Blend door actuator does not control left/right function. You need a driver temp door actuator. And disconnecting a fuse does not calibrate it you need a scan tool. Sent from my iPhone using Tapatalk Where is the driver temp door actuator located? On 3/9/2020 at 10:32 AM, tlaw91 said: Blend door actuator does not control left/right function. You need a driver temp door actuator. And disconnecting a fuse does not calibrate it you need a scan tool. Sent from my iPhone using Tapatalk
tlaw91 Posted March 13, 2020 Posted March 13, 2020 If you’re looking at the gas pedal it’s to the right of it behind the panel that closes out the center console. It’s right behind that vent Sent from my iPhone using Tapatalk
Dgjones Posted March 14, 2020 Author Posted March 14, 2020 I have all vents blowing cold air again, only issue is I have to go down to 60 to get cold air, any way to adjust this? I have tried taking fuse out. If scan tool will fix, is this what I ask for at store?
tlaw91 Posted March 15, 2020 Posted March 15, 2020 Only a GM dealer or a snap on modis or something can calibrate your HVAC module/ Sent from my iPhone using Tapatalk
tlaw91 Posted March 15, 2020 Posted March 15, 2020 Also it sounds like you’re low on Freon btw Sent from my iPhone using Tapatalk
slj2008 Posted March 15, 2020 Posted March 15, 2020 Take it to the dealership or local garage - might be low , condenser may be leaking , mine 2015 had to be replace ( waited 4 week's for a new one NOT cheap ) . good luck
Dgjones Posted March 17, 2020 Author Posted March 17, 2020 All of this was working fine until I changed the battery, just don’t understand how that can cause all of this. Thank you so much for your time.
