front control arm trouble (4/6 drop)
Hello Everyone and thanks in advance for everyones input.
I recently had a 4/6 drop kit installed on my 2p18 silverado extended cab. rear flip kit/shocks front: new upper/lower control arms.
The problem is over rough road bumps, freeway dips i noticed loud metal to metal noise/bottoming out in the front..Im trying to pinpoint the problem..and noticed this indentation on the lower control arm..could this be the cause of the noise?? what are some suggestions for a possible fix with this issue that yall would suggest?
Thanks again for the help!20200314_200742.thumb.jpg.6d8766b631f0e7db36e477cddc59f27b.jpg
stiffer springs?
maybe someone makes a lca that's a little curved to avoid hitting there?
The least desirable thing would be to cut the frame a bit so it doesn't hit there (as it will weaken the area where the lca mounts, which is not good).
    blueskytruc
    blueskytruc
  • Who's Online   6 Members, 0 Anonymous, 671 Guests (See full list)
