Anyone Tried "OEM Style" Running Boards?
I actually have the black versions.
I am happy with them in terms of function and fitment but I would say finish is about on par with what they cost in comparison to OEM. The metal they use is a pot metal so the surface isn't smooth and the brackets are fairly thin but I don't think I will ever put enough weight on them to push the claimed 600lb rating unless this COVID lasts for another 3 months and I balloon up from staying indoors lol. They don't flex at all with one person on at a time so although the brackets are thin visually, they are sturdy enough for me.
As long as they last a while and look good. I’ll never get to 600lbs either haha.
If anyone has any better options for that price point, please share!
$350 for factory oem 6" full length crew/ standard bed
11 hours ago, justin saleeby said:
ill sell you my OEM GMC boards where are you located?
Oklahoma
8 hours ago, snork said:
is your truck standard bed or short bed?
It’s a crew cab, so i think short
I also have the black version for my short bed RST. As I assessed some factory boards at the dealer I noted that my boards are lighter and hollowed out inside. But..for $165 free shipping on E@ay vs $800 at the dealer it was a no brainer for me. I like em. Sorry..wish I had closer pic on my truck.
Those look really good!
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 630 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
