Front Parking assist
Just got my 2020 Denali Monday and while parking i noticed that i don't heard any beeps when approaching an obstacle until the bar turns red then it starts to beep and loud. Shouldn't it beep faster as you approach and object? I checked the alert settings and it is set to beep. Could there be another setting?
Rear gives a beep on first detection.  Front does not.
The 'really close' Beeps happen sooner or rear than front. (1 ft front, 1.5 foot rear)
Presumably because it's easier to tell how close to stuff you are in front vs rear.
Park Assist
With Front and Rear Park Assist, as the vehicle moves at speeds of less than 8 km/h (5 mph) the sensors on the bumpers may detect objects up to
1.2m (4 ft) in front and
2.5 m (8 ft) behind the vehicle
within a zone 25 cm (10 in) high off the ground and below bumper level.
The instrument cluster may have a Park Assist display with bars that show “distance to object” and object location information for the Front and Rear Park Assist system. As the object gets closer, more bars light up and the bars change color from yellow to amber to red.
When an object is first detected in the rear, one beep will be heard  from the rear, or both sides of the Safety Alert Seat will pulse two times.
When an object is very close
—<0.4m (1.5 ft) in the vehicle rear
or <0.3m (1 ft) in the vehicle front—
a continuous beep will sound from the rear or front depending on object location,
or both sides of the Safety Alert Seat will pulse five times.
Beeps for FPA are higher pitched than for RPA.
My 18 works the same way.
No front beeps until it is 'very close'.
iirc, the closest bar is lit on the dic when the beeps occur.
Great thank you Redwngr for responding, so it appears to be working correctly then, my Tundra would beep slowly going forward or backward, i just took it for granted that they all did that. Thank you for the explanation, much appreciated. I love the truck, the handling, the power, the feel, its just worlds over my tundra. I am somewhat disappointing in the way it was delivered, door panels and door sills scratched up, fender scratched from wiping it off with a dirty towel, I'm sure if i press the issue they will fix it.
  • 5 weeks later...
My  2019 Silverado park assist kept blocking when I shift into Reverse . It works in morning when I leave then get to work I’ll shift into Reverse it blocks right away. This didn’t start happening until they did the Battery cable recall and the electric brake recall and the brake pad wear recall. I took it back in my sensor has a chip on it they this is what caused it said it wasn’t covered under road hazard warranty 420 Dollars to fix only 15000 miles on it not Happy.
wow, $420 to replace a snap in sensor that costs alittle over $100......they don't even have to remove anything to get to it, just unplug it, snap the old one out and snap the new one in, less than 5 mins in labor time........must have charged you for trouble shooting your problem.....bummer
    d.lowrey
    d.lowrey
  • Who's Online   2 Members, 0 Anonymous, 2,694 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
