97 gm gauge issues
trev65
greetings!  I have a 97 gm 1500 extended cab. 2wd with a 350.  having gauge issues.  replaced speed sensor.  seemed to go ok and then happened all over again.  fuses are good.  any suggestions?  also is it ok to drive as I need and can't afford mech at this time.
Not following exactly what your problem is here. Do you have a speedometer issue, or ALL gauges are an issue? You'll need a scan tool to verify whether or not your replaced sensor is operating correctly. This should've been done before replacing it - my bet is, it never needed one.
Keep in mind, these years were notorious for stepper motor failures in the cluster.
No harm in driving, unless you have low or no oil pressure.
thank you.  just an issue with the rpm and speedo. check gauge light comes on and both gauges stop working.  feels like tranny slips a bit.  all else is good.
I'd get a scan tool on there and do the "sweep" test. If the tach and RPM flake out during this test, you've found the problem. Two bad stepper motors. If you're going to do the repair yourself, do ALL of the motors, because the others will be failing any day now.
Plenty of companies out there that sell stepper motor kits. A Google search should turn up many. Just read the reviews and find out which ones are good.
    • Correct.  2019-2021 model years are serviced by a different p/n.  19420611.  Recall 2021s use 19420611.   The recall engines 2022-2024 model years are serviced with 12740076.     The difference between 19420611 and 12740076 is GM changed injector size for 2022.  The injectors are smaller on 12740076 with smaller injector bores in the cylinder heads to match the smaller injectors.  So you can't install a 19420611 in a 2022-2024, and you can't install a 12740076 in a 2019-2021.     Both engines are the replacement engine p/ns that are in the L87 recall.  So both of these are the updated engines.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
