The letter "z" is very tricky to get installed correctly because it's so deep to get the piece into position with the adhesive backing. Take your time and be patient. These really stand out and will look great on TB models imo.
Sent from my Pixel 3 XL using Tapatalk
Good to see you again Uncle Rico.
Saw the ad for your ESPN 30 for 30 special this weekend, looks good!!!
58 minutes ago, Porterhouse said:
I had not seen that commercial. Thanks for the laugh!
You are very welcome.
Nice "steak toss" by the way!!!
  • 2 years later...
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 839 Guests (See full list)
