sounds like what i’ve been looking at lately, haha. mostly seen 17x8.5, 17x9, 18x9 sizes & offsets around 0 to -15 and 12.5 wide tires. couple trucks i’ve seen pushed it to 20x10 -18 to -25. but it also seems the smaller combo has little to no rubbing issues. 10 wides had some tuck & trim in the fender. hope that helps
I’m curious too. I do t think I can fit 17s on my Sierra with the NHT package. Been looking at 18x9 with a zero offset with icon front coil overs at 2.5-3” lift. Found 305/70 in a KO2 that’s 34.8 12.2 wide on that wheel size. With icons UCA I’m worried I’ll need a spacer with the offset. Will definitely rub on the Sierras around the liner and mud flap
2 hours ago, Ksalway said:
35x11.50 on 3.5” lift +1 offset wheel. Had to remove the mud flap bracket and do some manipulating of the wheel well liners.
3.5 lift front and rear or 2” rear 3.5” front???
3.5” front 2.5” rear it’s the rough country lift
Ahh. Too bad their kit doesn’t fit my truck. I guess the crew cab is different from the extended cab
2020 RST Z71 with a Trail Boss 2" stock suspension. Added a 2" dealer/factory level kit. OEM 22" wheels (+28 offset) on 35x12.5 Nitto Trail Grapplers. No trimming with very minimal rub on mud flaps.
You have a side shot so I can see the poke?
so you have a 4” front lift and 2” rear lift? Is what your saying?
2019 LT 5.3
Supreme Suspensions- 3.5 front 3.0 rear, minor trimming in the wheel well. Mostly just rearranged bolts. Kumho Road Venture m/t. 35x12.5x17. 2” spacer but you could get away with 1.5. Standard Pacer LT aluminum wheels. 17x9 -12 offset, 4.53 backspacing. When I buy new tires I will probably go with an aggressive hybrid, lots of road noise from these particular m/t’s
3 minutes ago, Rado5.319 said:
2019 LT 5.3
Nice set up but too much wheel poke for me   Don’t want my truck with all the road spray from salt and mud
  • 1 year later...
Hey guys I’m new to posting so please bear with me. I have 2016 GMC Sierra 2500hd Denali. I’m looking to buy and install the RC 3.5” lift that includes the steering knuckles and UCA’s. My question is can I run 35x12.50R22 -44 wheels with A/T tires after installing the 3.5” lift ? I don’t mind trimming a little but not a lot. Wouldn’t this set up work ? Thanks in advance.
    ar0517
    ar0517
  • Who's Online   5 Members, 0 Anonymous, 636 Guests (See full list)
