Back to the shop, tailgate this time
2 hours ago, Intheshopagain said:
2016 Yukon xl denali, 70k miles. Been in the shop a lot. Now the tailgate opens a 1/8, I can press the handle button and another 1/8. Will not automatically open. Any tips?
Welcome to the site.
Maybe look into this:
Service Update 16046 Power Liftgate Actuator Failure – 2016 Cadillac Chevrolet & GMC
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
