Toyota clutch
timk49
My son owns a 93 Toyota Pickup with a 5 speed trans, four cyl. engine. and the clutch is slipping. 150,000 miles on the original clutch. Anybody got a quick estimate on the cost to replace the clutch. If you are in the Huntington Beach , Ca. area can you recommend a good shop to do the work.
Thanks
Tim K
I had an 89 Toyota, and my total cost for clutch, pressure plate, throwout bearing, and pilot bushing was under $150. But I did the work myself. Not too difficult. By myself, I did it in one (very loooong) day.
And the only shop in Cali that I could recommend is in El Cajon :smash:
Good luck with it :thumbs:
Thanks wingnut.
My son doesn't have access to a lift of other means of getting the truck up on jacks. So I think he has to take it to a shop. Would the labor be about the same as the parts?
Ammco Trans are they reputable?
I didn't need a lift, and it was a 2wd. But a jack and stands would be necessary. If it's 4wd.....he may not need those. The tranny isn't that heavy. He!!, I put mine back in without a jack. Just "benched" it up in there. Of course, I was only around 20 at the time.....And in great shape :thumbs:
I would say labor would run you quite a bit.
When I lived in San Diego, I had to pay to get my tranny dropped (In the 92) and it was about five bills, just to drop it, no parts, no fixing, just in labor. But a clutch is an in-and-out job....I don't know. Ammco....Did you call them? For something like a (relatively) quick clutch job on a Yota, I would imagine they would give you a pretty accurate quote over the phone.
Sorry I can't be of more help.
My 93 Toyota did the same thing at about the same time, 130K miles. Mine was a V6, don't know if it was any more expensive, but at the dealer, it was going to be about $750. I found a shop to do it for $100, plus parts, got it done for under $300. Chris
I called Ammco and they would only give me a quote if I brought the truck in for them to do their "free " inspection. I asked them if the free inspection included dropping the tranny to inspect the clutch but they wouldnt say anything unless I brought the truck in. I got quotes over the phone ranging from $500 to $600. total.
Sounds about right. Sucks....But that sounds (to me) to be in the right range.
You might find some smaller local shops for a little cheaper, clutches are pretty cut and dried (no tranny internals involved), so I wouldn't worry too much about how good their work is....Quality of materials on the clutch itself however, is another matter. :sigh:
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
