map light switch
I've got a 1997 Chevy Suburban with a bad map light switch (in the overhead console). I've Googled and come up with nothing other than a suggestion to try the Dorman 924-798 switch, which is too long. Does anyone have a part number or a source for a replacement switch? The switch itself has no part number and I can't find a parts diagram for the overhead console.
Edited to add: I have found the actual GM part, which the entire wiring harness containing the switches. That is Part # 12376309. Of course, it's discontinued and no one makes a replacement.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
