i get in my 03 sonoma 4.3L and after 10 minutes of driving my truck slows to 20 mph and will not go any faster even with gas pedal to floor.
i cut it off and let it sit for about 10 to 15 minutes then restart it and it runs fine for about 10 minutes then back to 20 mph, i've changed fuel filter.i changed oxygen sensors, it still does same thing, it idles fine and doesn't stall out just slows to 20 mph,,,, i appriciate any help i can get.
2003 gmc sonoma
king cab 4x4
4.3L engine
automatic, 4 door
Check for codes. Sounds like a fuel pump issue. I had similar, I couldn't go above about 40-45 mph. Swapped pump, all was well. Checking fuel pressure will probably be required at some point, especially when it will only run at 20 mph.
Codes first though
Have you checked the MAF connections or at least cleaned it with the correct cleaner? A replacement may be in your future
Note, if you do get another MAF sensor, I would suggest sticking with an ACDelco one, as they seem to perform better, at least with that generation truck.
I know with my truck, when I bought it, it had a bunch of codes, including P0101, I replaced it with a new Airtex?(I think, it's been years) one from NAPA, it seemed to work fine in general, but would sometimes still generate the P0101 code (generally when it was really cold during the winter).  I replaced it with a used ACDelco one from my parts truck, and that one has worked fine and hasn't generated a code since then.
I see a lot of great responses to your problem, and I will add my 2 cents. the P0101 for maf sensor was just 1 of my problems with my 2003 Chevy s10 4x4 w 4.3. It spread like a virus once that one hit around 125000. I replaced mine about a year and half ago now. But that is also considered a generic code for all GM vehicles. I cleaned mine with cleaner and a soft brissel brush with no avail. So I replaced it with one off Rock Auto and it works just fine, it is an AC delco Reman. Then my head gasket went out, distributor was bad. and fuel injectors were bad. I am the 3rd person to own the truck, so you can see whay I inherited. After all that had the crank sensor go out. So start with the new maf sensor, but I dont believe its causing your loss of fuel pressure. That sounds more like your pump and sensor is going out. But I have heard of strange things clogging up one end of the fuel filter and folks still had same prob after putting in new fuel pump. So make sure you change out fuel filter as well.
  • 1 month later...
I’m having a similar issue. 03 gmc Sonoma. At lower RPMs feel a little rocking  /shaking then get codes P0300 and P0151. Replaced plugs /wires and o2 sensors. At higher rpms runs smoother but then check engine light comes on flashing. Truck has 248,607, motor has 5,431 on it. I’m lost.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 769 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
