Solving the MPG Dilemma
On 6/3/2020 at 12:16 PM, Marztian said:
MPG used to be ~18 avg - right along with what one would expect and what most people get. Since last Fall (September 2019), I've been getting 12-13 city and 14-15 highway.
The purpose of this is to try to find a SOLUTION, or at least get pointed in the right direction for one.
When did you put the KO2s on?  What brands of gasoline are you using?  Some really are better than others.
My own truck picked up about 1/2 mpg on average when I installed the ACDelco drag reduction clips on the front brakes only.  These keep the pads off the rotors better than the ones built into the slide clips.  Also picked up another 1/2 mpg or a little more when I switched off from plain old Mobil One to ACDelco's oil made for aluminum block engines.  I think Marty picked up about 1mpg when he switched to a different transmission fluid.
Next time around, if they make them, consider running a Load Range C tire and not E.  My KO2s are just 8 pounds more than the stock Goodyear tire.  How much air are you running in the tires?  Too little will kill mileage too.
Take and send out oil samples of our engine oil and transmission oil.  I think you'll be surprised with the transmission fluid.
K02s got put on about 2 months after the noticeable MPG drop. I run them at 40 psi- so although I’m sure there is more drag because of tread pattern/weight, it shouldn’t be awful. I will look into the brake clips as it’s a neat idea that has potential for cheap investment. I pretty much always get gas at the new Casey’s station in town (87). Just started experimenting with UNL88, too. If anything, I’ve seen no overall drop, if not a gain ? in MPG.
I have AMSOIL fuel efficient 0w-20 oil, and their fuel efficient transmission fluid that I’ve heard great things about, to change out at the next OCI. Already switched both diffs and transfer case to AMSOIL. I will also be doing samplings prior to the change of both as a control comparison.
I learned from a friend that those DI motors don't see much, if any change in performance when switching octane ratings but like every other gasoline engine, responds well to higher quality fuels.  It also responds differently to different brands.  I did not find Casey's listed as a Top Tier fuel.  Run a few tanks of Chevron or Mobil, preferrably 93 and see how she does or stick with the E15.  The trouble with E15 is consistency, all too often I get a tank of 87 with no additional ethanol in it if their blender pumps are turned off.
Mine gets its best mileage on fuel with an alcohol content of between 16% and 22%.  Amsoil fluids can add about 1/2 to 1 mpg so that's good.  Tire pressure might be a little low, the lowest recommended air pressure is about 42 psi front and rear which covers your axle ratings and then some.  You're not much different so just watch how they wear and adjust if necessary.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
