Need a little help 2000 gmc savana
Oilkann
The belt keeps walking off the crank pulley just a bit. Can figure out what’s causing it .Replaced the tensioner and idler pulleyReplaced the tensioner and idler pulley
Did this just suddenly start doing this or did you changed any other belt driven devices recently? were you having the issue prior to tensioner and idler change? Harmonic balancer/pulley running true and not wobbling? Check alignment across the face of pulleys.
I purchased the vehicle , and noticed it was shredding the belt like that so I changed the tensioner and the idler pulley trying to clear it up.  Bit both didn’t help a thing
I’m curios as to what you can do if it is a bad pulley alignment , being all the items just bolt in place no shims , also I’m pretty sure I stripped my crankshaft bolt out check to see to see if it was tight ???
