What lifts do people recommend?
Hi guys,
I just bought my first vehicle, a Chevy Silverado crew can 1500 custom.
I am very much a noobie. I wanted to know the different kinds of lifts people have and how it affects driving. I’ve been looking at getting a 3” lift but have no clue where to start. How different is a 3” lift from a 6” lift? Are there huge differences? Or if there is little difference, is it mainly the price that is a the big difference?
What would even be a fair price for a 3” lift if I were to get it done some place?
thanks guys!
