Smoked LED Fog Lights????
Im on the look out for some smoked LED foglights for my 2016 Silverado but not having a lot of luck finding that many. The few that I have found I'm not sure if there reputable companies. Does anybody on here have some installed on there truck and if so can you please post some photos? Also what are some good aftermarket ones that people would recommend?
Thank you.
Thank you.
This is the route a lot of members have taken on the site. The LED's are "all one unit" can't replace the bulbs, has to be all or nothing.
15 minutes ago, Roscopcoletrain said:
Yeah I use amber Lamin-x for mine. The Morimoto LED fogs are supposed to be good.
OP has his trucked listed as a 2016 and the Morimotos I don't think will fit any of the vertical style fog lights on the 2016+ K2's. I could be wrong but TRS couldn't answer that for me. They said "we're not sure" when I called them. I'd fork over the cash for Morimotos if they had them for 2016+ K2's.....
I totally didnt think of the 16 having different lights. My mistake. Good catch!
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 827 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
