Replaced Left Eng Mount - Need Do Both?
I spent a few hours yesterday replacing left side engine mount.  Do you have to replace these in pairs?  I don’t think the right one is bad per say.  It’s a bear of a job re: recessed/hard to get to bolts.   I’m just wondering what standard practice is.
12 minutes ago, CamGTP said:
No, not really.
, I've always done just what was bad at the time.
cool, because its not the most fun job and the OEM ones arent free.
