I have a 91 k1500 Silverado, has an automatic transmission, and tilt steering. I have replaced the tail light assemblies and boards within the last year. All bulbs are new. I have been having to pull the turn signal fuse in order to put the transmission in drive for quite a while. Up until yesterday, I could put the truck in drive, then stick the fuse in, and the turn signals would work fine. Now, the fuse blows as soon as I put it in, regardless of what position the shift lever is in. I drive this truck for work everyday, so I need to get the lights working properly. Any help would be greatly appreciated.
49 minutes ago, Marcushogun said:
That's what I was thinking too. Short of tearing the column apart, any suggestions on how I can fix it?
Gonna have to tear into it to find the bare wire
Had to do this on a 84 K20 HD, steering column per se doesn't have to be torn into, but the steering wheel itself has to come off, a lot more complicated now with an airbag system, so OP if you're not comfortable with that, find a competent mechanic.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 445 Guests (See full list)
