So I've always used Opt7 Fluxebeam H11 headlights for my 2014 Silverado LTZ Crew Cab and have been happy with them. Sure they die right after the two year warranty, but they've worked great in the heat and the winter (although the fan sounds pretty bad when it's super cold)
Today I noticed one bulb is out and I look online and see that they are no longer available.  Maybe it's the virus, maybe they were discontinued, who knows.
But being that these bulbs are 4 years old now at least since I've started using them, I figure technology in LED lighting has improved since then. What do you guys use? And do you currently have the dust cap installed (or at least can you install the dust cap with the LED bulb on) -- I want the dust cap on for my truck
Maybe one day I'll have a headlight without a fan on it (we can dream can't we?)
Go for the GTR Ultra Series 2 or the Morimoto 2.0, these are made of better quality hand components than the Opt7s, and will last much longer.
Here is some information I found when I was looking for better lights. I went with the SV-4 and don't regret it. Hope this helps.
Thanks for the suggestions, went ahead and ordered up some morimoto 2Stroke 2.0‘s from amazon, they look smaller and improved design wise from the Opt7’s. Seems they came out in 2018, here to hope that they outlast the warranty and if not that the company is still around when they do. $129.90 after tax for me, other ones were a bit more expensive (but that lifetime warranty seems tempting)
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
