I recently installed the kicker tailgate audio system. I got it through GM parts direct. Installation was fairly easy. The system worked fine for a while. It stopped working one day.  I believe it is tied to hooking up a utility trailer. Hasn’t worked since I hooked up for the first time. I contacted kicker and they actually sent me a new system. I’ve installed that, It’s still not working. It does not seem to have power. I’ve checked and double checked all connections. Seems like I’ve blown a fuse. Does anyone know what fuse would have blown? I’ve gone through the fuse box and don’t see any that are noticeably  blown. I’ve heard of people hooking up their trailers on newer trucks and having a short in the trailer wire. This will blow a fuse. I’m assuming the kicker system is on that same circuit. Any help would be appreciated.
Grab a volt meter and check for power at your trailer plug receiver.  Chances are, you will have an extra wire with no voltage. (the ground being the other wire)  Chase that wire down and see where you lose power.
Thanks for the response. I’ll try that. Do you think there’s an additional fuse somewhere in the line? I went through every fuse in the box, and they were all good..
I own a 2020 GMC Sierra 1500 AT4.  In a previous post I described my kicker audio tailgate system stopped working. I think it’s directly tied to hooking up a utility trailer about a month ago. I think I just simply blown a fuse. I have gone through all of the fuses under the hood. I just recently discovered the two other fuse boxes in the cab. I can’t believe I didn’t know they were there. Is there anyone on here who knows which fuse runs the kicker audio system? I assume it’s the same fuse that runs something in the trailer hitch.
Thanks
  • 6 months later...
Just had the very same issue on my 2021 GMC 3500 after towing my travel trailer.
The local GMC Dealer traced it to the 30 AMP fuse in the block under the hood.
Fuse part is 22917202 (large 30 AMP fuse)
Fuse circuit is No 63 (TRLR BATT)
Kicker Stereo works fine now but let’s see what happens when I hook up my trailer next time?
  • 3 months later...
I’m sorry, I know this is an old post. Any resolution to kicker not powering up? Have you located a fuse? I recently towed a trailer but just hooked up and all lights work. Could it be mid gate switch not telling truck it is open allowing for power to kicker? Thank you so much for helping in advance
  • 5 months later...
There is a fuse right behind the rear license plate for some reason mine keeps popping and the kicker system stops working.
This happened to me too. It turned out the installers did not fasten wire under the tailgate covers. Wire kept rubbing on one of the hinges and exposed wires and kept shorting itself. Take the plastic covers off (use T30 and T20 I think) and follow wires.
Edited by Bryanw
  • 5 months later...
I have had this issue for a while and just now found out my problem. It was the 10a fuse behind the rear license plate that had blown at some point and filled up with a bunch of corrosion. Going to have to work on that tomorrow.
If your tailgate system stopped powering up. A few things to check. If you have recently connected a trailer to the 9 pin trailer plug. Check the fuse under the hood for the constant 12v power to trailer. If it is good there is a smaller fuse under the truck around the rear licenses plate. If all of them are good. The next thing to check would be the position switch that senses what position the tailgate is in. To test you will need to remove the cover or baffle. once inside the gate make sure it is opened to fully so you have to have the second gate open also. Then check power at the amp. If you have power it could be a bad amp. If you do not have power its the position switch. Once you figure that out its simple to fix. Your system if purchased through a GM authorized dealer you have an incredible 3 year / 36k mile warranty through any GM dealer in the country. Even covers the labor under warranty.
 I have a 2500 denali with same issues. 30a fuse under the hood was blown, replaced but still no power. Where is this 10a fuse located behind the license plate? All i see is a schneider box/sensor thing.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
