Cylinder 4 misfire
Duckie
I have. A 2012 Yukon Denali Xl I am getting a cylinder 4 misfire and I am stumped replaced the coil wire plug and injector stabi track and traction control lights are on have had a compression check done mechanic said it was good but there was carbon on top of the piston have ran 2 cans of sea foam thew the gas no help I am stumped any ideas?
Check for a broken valve spring.
The other thing it could be is a bad AFM/DoD lifter as cylinder 4 is a cylinder that shuts off at cruising speeds. The lifter itself could be bad or it wiped the lobe off the camshaft.
I guess if all factors are good and replaced new (Coils, wires, spark plugs, injectors, and compression test), then I suggest checking EVAP sensor, oxygen sensors, and fuel pump.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
