When a front hub is replaced does the wheel alignment need to be checked or adjusted?
We had one done on our 2008 Tahoe and 10,000 miles later the outer edge of the tire is bald. The issue is that I didn't really notice the condition before the hub was changed do it may have been oddly worn before.
The opposite front tire does not look like that and seems to be wearing normally.
Tire pressures have been maintained at good numbers but tires have not been rotated so the issue isn't elsewhere.
I also changed the front struts a while ago, but again, the opposite side front tire is not showing an issue.
So you did:
- possible bad hub
- alignment
- new struts
- worn tire
Yes, redo the alignment, and to be safe, with a different shop. They should have found the worn hub when inspecting the suspension before alignment.
No, not as you listed. Replaced definitely bad front hub, a while later I replaced the front struts, one of which was definitely bad. A while later one front tire, the side of the replaced hub, is balding on the outer edge. No alignment was done after any of that work. Alignment was done before any of it was found and done when tires were replaced due to normal use over 60,000 miles.
The mechanics shop is trusted and only possible oversight was not realigning after replacing the hub, but perhaps it wasn't necessary; Thus the question was posted.
Maybe the bad strut caused it, I don't know.
I've never done an alignment after replacing a wheel bearing on a vehicle like this. Be it in a shop I used to work at or at home.
Removing the bearing on these trucks does not involve anything related to camber/caster or toe changes. All of those pieces stay in place. A wheel bearing is only 4 more bolts past a brake job.
In that 10,000 miles, it's very possible that a pothole, curb or whatever knocked the truck out of alignment.
The front shock replacement probably should have been followed by an alignment.  The 08 has the coil over design, not just the separate shock right?
Excessive wear on the outside tread usually indicates a toe out condition, which a loose whee bearing would cause. But I would think both tires would be worn if this was the case, but I'm no expert. Could possibly be positive camber from the strut replacement, but i think thats unlikely. I would definitely get the alignment checked regardless
Sent from my LM-G710VM using Tapatalk
Correct. They came fully assembled from the manufacturer though. New spring/shock assemblies.
Only one hub/bearing failed and was replaced.
Seems to be a consensus on getting an alignment so will do after both front tires are replaced. Mechanic said "curse of GM trucks", and he drives one.
I an trying to figure out what the culprit might have been to be sure it's resolved, at least as sure as possible. It seems that one of the two item changes could be the issue.
Edited by Beamie
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,200 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
