So i have a 2015 Chevy Silverado 1500 crew cab with the NON-Bose system. I recently bought a 4-channel amp with new door speakers and a mono amp for two 10 inch subwoofers. To combine the both im going to install the Audio Control LC7i LOC. The issue im having is finding a harness that will plug into the LC7i. The LC7i has 4channels for the speakers and another 2 channels for subs. It also come with a remote section. Is there a plug an play harness that connects the factory stereo to the LC7i? I know LLJ customs makes the wire but their customer service is horrible and i need the system finished relatively quickly. Or does anyone know a T-harness manufacturer that has a harness similar to theirs? Cause i dont want to do any tapping or re wiring, just straight plug and play. Thank you in advance and sorry if this has been asked before
i'm also interested in upgrading the audio in my truck, the speakers are already blown on the upper dash of my truck, whats a good upgrade?
What exactly you are looking for? Do you have any requirements, budget? Let me know maybe I can help you.
Yes there is a way to do it without cutting into anything. Check out my thread on gmfullsize from a few years ago. I can easily return my truck back to stock with this setup. All the harnesses you need along with the steps I took is in the link. Also you can use the red and black from the amp bypass harness for power and ground instead of tapping into the factory harness.
https://www.gmfullsize.com/threads/2017-crew-cab-silverado-audio-upgrade.308436/page-2
Metra 70-2057: http://www.metraonline.com/part/70-2057
Metra 71-2107: http://www.metraonline.com/part/71-2107
Metra 72-5600: http://www.metraonline.com/part/Ford_wire+harness_72-5600
Stinger Speedwire: http://stingerelectronics.com/catalog/wire/9-conductor-speedwire-20ft
Wiring:
Factory Green Harness
Left Front/Dash Speaker (+/-) Blue – Brown/Blue // pins 1 - 9
Right Front/Dash Speaker (+/-) Yellow – Yellow/Black // pins 2 - 10
Left Rear Speaker (+/-) Green – Green/Black // pins 3 - 11
Right Rear Speaker (+/-) White – Blue/Black // pins 4 – 12
Power // Red // pin 8
Ground // Black // pin 16
Metra 71-2107 Reverse Wiring Green Harness
Left Front (+/-) White – White Black // pins 1 - 9
Right Front (+/-) Gray – Gray Black // pins 2 - 10
Left Rear (+/-) Green – Green Black // pins 3 - 11
Right Rear (+/-) Purple – Purple Black // pins 4 – 12
Power // Yellow // pin 8
Metra 70-2057 Amp Bypass Green Harness
Left Front (+/-) Pink – Pink Black
Right Front (+/-) Blue – Blue Black
Left Rear (+/-) Red White – Red Black
Edited by chris15706
    KJEK
    KJEK
  • Who's Online   2 Members, 0 Anonymous, 516 Guests (See full list)
