Sorry if this was discussed... the search in tapatalk sucks.
Ive seen some put a piece of material behind the grill to make the grill lettering coloured.
Want to get rid of the work truck looks but keep the offroad look like the trd pro and rebel with the brushed aluminum lettering.
Anyone done this? I dont have my truck yet so take it apart and see for myself.
My company has a ton of anodized aluminum on hand and was thinking of throwing some behind or white to match the paint.
Also its a piss off this trucks called a “custom” makes googling very annoying
47" x 2 7/8" fits perfectly. Have some pics I can share with ya. More pics to come.
Yes please
47x 2 7/8" strip cut from metal roofing. Painted with color match spray paint, coated with rock guard clear vinyl and inserted in grill.
The tricky part is removing the 2 piece grill. Remove top cover. And the 2 piece front part is installed with clips on the back side. I grabbed the grill near the z71 logo and near center and with a swift pop, pull outwards, bit not over 2" or so out, cause once clips are loose, it comes out and up to clear. Move to center then other end. It is really scary to do the first time. The Chevrolet strip has a scree at each end and about 20 clips. That's easy insert and reassemble.
Luckily im an estimator at a commercial glas and aluminum company. Ill just get the boys to rip some anodized aluminum!
Edit:
Went downstairs and they sheared it in 30 seconds with the press. Just a dial... 2.875 boom cut. Then 47, boom cut.
Now to install this weekend.
Awesome! Can't wait to see pics!
Looked good but was too thick [emoji1304] couldnt get the clips to click.
Dang it.   Mine was really tight using metal roofing. Thx for the update.
    ncleg
    ncleg
  • Who's Online   1 Member, 1 Anonymous, 1,386 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
