Bed/canoe racks
Hi all
I need some expertise. I purchased a 2020 Silverado RST and I need to install a bed/canoe rack. I had one for my previous truck and this one will not work. I have  hard tri fold tonneau cover on the RST with its own integral frame and the old one will not fit without removing the cover. I was looking at the ADA-RACK system where the two rails mount into the stake pockets and if I get the straight uprights I can still use the tonneau cover. Does anyone have any experience with these racks and are there any mods needed to make it work??
Many thanks in advance
Cheers
Hi all
Cheers
Just installed the Adarac for the very same reason you are. Super easy install. No mods. I get compliments all the time.
Sent from my SM-G986W using Tapatalk
Thanks for the reply. just what I wanted to hear. I may have to trim some of the plastic that is formed down into the stake pocket so the metal mount doesn't try and lift of the plastic bed rail cover. Did you have to do this or did the mounts supplied work without doing this?
7 hours ago, Jaywroe said:
100٪ . Thats exactly the cover I have.
Could you post some pics when you have time ?
Thanks!
