My 2015 Sierra was throwing Trailer Brake System warnings, so I dropped it at the dealership for diagnoses and came up with a bad Controller. I ordered a new one from Rock Auto and will be swapping it out myself. Any tips, tricks or tutorals appreciated.....looks simple enough, just want to make sure I don't break something from one of those hidden screws. Thanks in advance.
Several good videos on You Tube showing this repair, it’s not difficult. Good luck,
Thanks. I did try a search on you tube and couldn't find a video on the '15 Sierra, or anything that looked like my Dash. I'm sure it's an easy swap. Dealer wanted $230+ to replace it, I bought the part for $40 to my door, just don't want to miss something and break a panel.
Edited by Beer Belly
    • 2026 3500HD.  Mostly empty. Grocery getter. What tire pressure are you running for 37x12.50x20. I have 37x12.50R20 Toyo Open  Country RT pro and been running around 55 lbs front and rear and it's too much. Tires are wearing more in the middle. Toyo says 45 front and 50 rear. Chalk test and it's still too much. I lowered it to 40 front 44 rear see what happens.
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
