Got a 4” BDS kit on the way for my 2019 Sierra SLT. Going to run 35x12.50s on my stock 20” snow flake style wheels. Running a hybrid tire that true size will be about 34.75” x 12.52”.
Question is this: what size wheel spacers could I try? Going to toy with them before I switch wheels. Always been a fan of the stock ones.
Since I’m only on a 4” lift instead of 6”, I know I need to be careful with any offset as that’s where all my clearance issues will be.
I see guys running this tire size on some leveled GMCs with trimming (I’m happy to do some trimming too).
Could I get away with a 25mm spacer making the offset almost 0?
Curious to hear some opinions, TIA
A 0 offset will be too much without trimming. I believe I have seen people here run 1/4 inch spacers roughly 7mm and able to clear 12.50s. Its not much and won't have your tires flush with the body but will prevent you from having to trim too much.
I've seen guys run stock lugs with the 1/4 spacer but you lose a few threads. I personally would order new studs 1/4 inch longer
Sent from my SM-N975U using Tapatalk
Also the BDS and zone 4" kits will push the front wheels out with the new spindles anywhere from 1 to 2"s on each side depending on who you ask.
Any idea how much I’d need to trim at a 0? If it’s just plastic on the flaps and bumper and pulling the fender well carpet back with a zip tie I’m not worried about it. Would prefer to stay out of the metal on the bumper though.
Good point on the new spindles increasing track width, forgot that. Makes sense now why I see guys running small spacers up front but 1” or 1.25” rear.
You shouldn't have to run spacers up front because the lift kit is already pushing the wheels out. I've seen some people say it pushed it out between 1 to 2 inches so you shouldn't rub on the UCA. I'm guessing with a 12.5 wide and being a gmc with the squared wheel wells, you will probably have to trim the plastic and remove the metal bracket behind the front wheel wells that hold the mud mudflap on. I cant see you having to cut the bumper though.
So you may want to install those and see how much it pushes the wheels out then order spacers for the rear to match the front track. My guess is you'll need 1.5" spacers for the back
    tblt44
    tblt44
  • Who's Online   6 Members, 0 Anonymous, 655 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
