I would like to install a leather wheel and the silver trim on my WT. Does anyone know the part number for the wheel or the silver trim, I obviously don't have radio controls. Will all the plastic pieces from the plastic steering wheel work on the leather one.
Sorry to hijack this but related... does anyone else find that the steering wheel is skinnier than those on FCA and Ford vehicles?  I feel like it takes some getting used to.  I miss the indents for your fingers too lol.
have a 19 trail boss custom and would like a leather wheel for it asap! if the volume controls will plug into a preexisting and unused harness behind the wheel that would be great!
    Dom Colussi
    Dom Colussi
  • Who's Online   4 Members, 0 Anonymous, 693 Guests (See full list)
