If I swap wheels and tires from 18" to 20" is there something in the electronics to be changed? Our '08 wheels are badly oxidized and get slow leaks in cold weather (corrosion on bed surfaces assumed), but it is ending up hard to find 18" take-off wheels now. There seem to be a better supply of 20" wheels so what would I be getting into with regard to setting up the truck?
Edited by Beamie
You only have to change stuff in the computer if you are super paranoid about it being 100% accurate.
If you keep the overall tire size pretty close to the same you will not really notice much difference at all. There are online calculator you can plug the data into to see how far off your speedo will be. Depending on what you do it may be off by 2-3mph at 70 going down the freeway.
So nothing involving ABS or anything but speed accuracy?
Correct, the ABS will still function the same way.
People will put 33's or 35's on their vehicles all the time without doing a thing, they just choose to live with very far off speedo.
So going from say a 265/65/18 to a 275/55/20 is a change in size and will put the speedo about 1mph different at freeway speeds. The larger the tire you go, the more off it will be obviously.
Edited by CamGTP
The short answer is no, you don't need to change a thing. Case in point, I changed from a 16 inch, to an 18 rim/tire combination on my 2001 Sierra. The tire diameter change was 1/10 of an inch.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 901 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
