I'm looking to put headers on my '14 sierra 5.3, the issues rises as i'm in NY state with their BS emissions inspection. Anyone in NY have options that they have done successfully? TIA
Edited by MtN33R
Where in NY are you? I've done full exhaust systems in previous vehicles (including headers) and had no issues with passing inspection. I used to bring one of my vehicles to the dealership to inspect just because it was easier for me (and that car was highly modified). As long as you don't have a CEL you should be good to go.
I'm in sullivan county, NY. Thats what im afraid of is a CEL because of the o2 sensors,  I rather not spend $1700 on high flow cats with long tubes. Just weighing my options here with some research before dishing out the doe!
try doug thorly  tri-y's torque headers...going by Cali emmisions .. as long as you got cats on and the check engine light ain't on , your good!
I’m in Orange County right below you. I have Texas speed headers with no cats. Before I had my rear monitors turned off, I ran 90 degree o2 extensions, CEL never came on. Had it inspected twice so far by Barton Birks in Newburgh with no issues
Thanks for the input man. Looking at the TS headers and y pipes they're pretty reasonably priced, might send it with a pair of their LT's and catted y pipe.
Definitely do the catted y-pipe. I didn’t and it’s way to loud
Haha for sure man, this is my daily driver so don't want it to be obnoxious.
Wow....great information. I’m in upstate and have been thinking about this myself. I’m in Saratoga county.
    DaleB
    DaleB
  • Who's Online   4 Members, 1 Anonymous, 1,533 Guests (See full list)
    • If there are updates/fixes you want, you could pay to have the updates applied by the dealer.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
