Was curious how some have gone about re calibrating the speedometer on a set of 35" tires. Im mostly interested in getting the MPG reading to be as accurate as possible.
I recently installed 35's on my AT4 and found only two options for recalibrating the speedometer.  Both Rough Country and Hypertech sell calibrators for $200 and $230 respectively.  My speedometer is off about 4 mph at ~70 mph.
I haven't bought either as I can live with it being off instead of spending over $200 just to get it correct.  Additionally, there are numerous discussions on this forum and elsewhere online by numerous purchasers reporting functionality issues with both units.
  • 3 weeks later...
I used the hypertech. I tripped a code/engine light after a month or so. I had Autozone clear it and it's been solid ever since.
I used Hypertech as well, no issues for a year / 10k+ miles.
    flyclt
    flyclt
  • Who's Online   5 Members, 0 Anonymous, 636 Guests (See full list)
