Bridgestone Dueler A/T's any good?
I have them in the Revos. They are by far the best all around truck tire that I have ever purchased. We have had a bad winter thus far, and the really bite into the snow and ice. They are also smooth and quit on dry pavement. Only have about 5,000 miles on them so I can't tell how long they will wear.
Well worth the money!
I have AT Revos on my Rado with about 18k on them. They are a vast improvement over the stock f-stones. Great wet and snow traction, a comfortable ride without a lot of noise. The tread is somewhat aggressive, and best of all, the price was very reasonable.
I looked at these as well as Coopers. The BFG's and Michelins are just ridiculously priced these days. I ended up going with the Cooper S/T. However did my homework and was on the fence between the Coops and the BStones, nice tires.
Last sunday I put two dueler a/t's (not the revos) and two cooper discoverer m+s tires on my truck. This was to replace the WORTHLESS goodyear wrangler st tires that came stock, I couldnt bear another winter with those things. The ride is a very slight bit more firm, I can hear a little tire noise that I think is coming from the duelers, wet traction is INCREDIBLE compared to the stock slicks. So far I am very happy with my decision, these tires seem very well suited to my truck. I have heard that you get pretty close to the claimed 50k miles on the duelers which isnt bad for a moderatly agressive tire like that.
a/t's are a little cheaper, little less funny looking, more of an old tech type all terrain tire. The revo's are more money, more street oriented, and have a kind funny looking tread to me. They should be quieter and better mannered on pavement and probably equal or close performance off-road. I just like the way the a/t's look and didnt want to spend too much either.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
