Does any one on the forum run the Kryptonite stage 3 leveling kit with fox shocks? If so what is your opinion on the kit. Good buy or waste of money?
My truck is a 2018 silverado custom double cab. 4.3 V6
I was seriously considering that kit.  Seemed like a good kit and the price seemed reasonable.  Then I decided I wanted adjustable ride height shocks.  The ones in that kit are not adjustable on the truck.  You need to go up one more level in the Fox lineup for on truck adjustables.
Sorry, that was wrong.  I looked at the package again, and they are the IFP shocks, so they are ajustable on the truck.  Those shock go $490 each and the rears are $170 each and the arms are $500 for a pair if you buy it all separate, so $1820 total.  That makes $1700 for get package pretty good.  It would cost an extra $420 on top of the individual prices to go up to the 2.5 coil overs.
Edited by Mike GMC
Heads up you'll need spacers or new wheels with their UCA's. Their rep recommended 4.5in of backspacing to me. Ride and look great
I can confirm this. I did a 2.5” level and Kryptonite control arms and the stock wheels rub the control arm at about half lock of the wheel.
On 10/2/2020 at 6:15 AM, MasonB said:
What wheel size and offset did you go with on your truck or did you go with the spacers?
I went from stock 18s to XD844 Pikes at 20x9 0 offset. Just ordered some small spacers for the front. I feel like the wheels might touch the arms at full lock at certain angles. If I had to do it over I'd go with the Readylift UCA's and tap grease zerks into the bushing housings
For those that had rub with stock wheels, were they the 18" or the 20" wheels?  Maybe it doesn't matter, but just curious.
My stock were 18s, but considering I still have slight rub on 20s with 0 offset I guarantee stock 20s will have major rubbing
Edited by Shea Albers
I had the 20” OEM snowflakes.
  • 3 years later...
Did you rub on the kryptonite uca and if so how much spacer did you need ?
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
