I just towed my travel trailer with my new 2020 Silverado, with the factory brake controller. I had a 2020 Colorado ZR2 Bison prior, which was totaled in a crash last month. Prior to that, I had a 2017 ZR2 with the Diesel engine (which was replaced twice). In both Colorados with the factory controller, I would end up with a gain of about 4.0-4.5 and get excellent control of the trailer braking. Towing with the Silverado, I ended up with a gain of 7.5 with the same trailer. In addition, I feel like even with a higher gain setting, the braking performance wasn’t at all what I expected from the bigger truck.
The trailer is a 2018 Keystone passport 175BH, max weight of 4500lbs, probably about 3500 when I’m moving from my house to the storage lot and vise versa.
Am I wrong in thinking that the gain setting would have been about the same with the same trailer, considering they are all GM parts?
I’ve never had to go higher than 4.5 and my trailer is usually heavier than that. Anything more and they want to lock up.
Have you verified the trailer brakes are still good and operable? In my last vehicle the numbering was different but from min to max but the relative gain was about the same.
Brakes are good. I hooked it up to my neighbors Sierra this evening and with the gain set on his at 5.0, the braking was quite a bit better. I'm gonna make an appointment for the dealer to check it out.
I have a keystone passport 239 which is probably 5500 lbs fully loaded 2 axles. I seem to settle in at about 6 to 6.5 on the trailer brake depending on truck load to make it feel "right".
Sent from my Pixel 4 using Tapatalk
Just to follow up on this. I had it in the dealer and they did some testing. Tech up cleaning the connector on the truck side and everything works just fine now. Didn't even cross my mind the connector might need cleaning on a brand new truck.
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,395 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
