The stock stereo is pretty rough, so was curious who has gone through, left the stock deck but either used the GM/kicker stereo upgrades, or their own and had good results?  As well as what you went with?
thanks!
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
