2011 GMC Yukon: I've replaced my PS pump twice in the past month with new AC Delco, OEM units and the second pump is still noisy. I've flushed the system completely, used Valvoline PS fluid, replaced the pressure and return lines, used new seals on the lines at the reservoir and steering rack, and bled the system at least 5 times. The pump still whines especially when turning. There is no sign of air in the reservoir (bubbles or foaming) nor any sign of fluid leaking. Are these made in China pumps that unreliable or am I missing something?
There could be air pulling into the system at one of the hose connections without a visible fluid leak but I would think that would result in air bubbles in the fluid.
Any thoughts are appreciated. I dread the idea of pulling this a third time and dealing with the inconvenient Rockauto return process.
  • 3 weeks later...
To close the loop, the pump was defective. Pump #3 is dead quiet. It's unfortunate that 2 of 3 new AC Delco pumps were duds but I guess that's what we get with inexpensive made in China parts.
For anyone considering buying from Rockauto, it's not the best experience if you encounter more than one warranty issue. You have to pay for shipping for both replacement parts and to return the defective parts. Worse, there is no option to request a second warranty replacement for a part that is still within the warranty period and Rockauto offers no email or phone customer support. I spent an additional $25 shipping parts and waiting for days which was no cheaper than buying locally. A better option for auto parts is Amazon which is free Prime shipping, they cover shipping both ways on warranty parts and they don't charge you for a replacement as long as you return the defective part within a week.
    • Disassembly may be Required!   Every blender makes claims but do  you ponder those claims? What was really said? Was it true?  Motive for saying it? What does in infer?  Is that inference true?    Let's do one.    Claim: Made from shear stable base oils.    What was said: Base Oils are shear proof.   Was it true: Yes.  ALL base oils are Newtonian.    Motive / Inference: To imply the fully formulated product is Shear Proof.    Is the Inference true?: Most fully formulated multigrade oils contain Viscosity Modifiers or VM's, sometimes called VII or Viscosity Index Improvers. There are four types. One is in fact shear proof but it also has a bad effect on extreme cold flow and is restricted to use in specialty oils. A second has limited shear called a 0-5 SSI polymer. Meaning its shear is limited to a range of zero to five percent as reported by the ASTM D6278 Shear Stability Index test. A few high end oils, like Torco SR-5, use them and brag about it profusely. Actually all that use it point it out. The last two shear dramatically and are often marketed as a 'feature' of the product aiding the oil to meet fuel standard requirements of ever stricter rules. One shears more than 5% and the other up to 20%. As you make guess, cost is directly linked to shear down and as such the majority of oils use the cheapest organic polymers sold to make grade and pass stringent tests.    PPD's or Pour Point Depressants also shear a bit, only a few percent and hide inside the 0-5 SSI capabilities.    The blender knows he can not out engineer Stribeck. Physics is not a suggestion. But he can wordcraft the unsuspecting toward believing a false claims INFERENCE. This is LEGAL. It is COMMON, and it is EFFECTIVE.
    • I don't recall ever dealing with one on an '06 and back. It may not even exist on that. I can't remember for sure.   Any kind of ice in or after the evaporator is normally due to low charge with both a clutch-cycling orifice tube system, and a TXV system.
    • Engines wear. It is unavoidable. So the question isn't if it will wear out but rather WHEN it will wear out. That question is about rate and RATE is a HUGE problem for almost everyone; but not in the way we may think.    Unless there is something drastically wrong with your powertrain, wear is exceedingly slow. It doesn't wear out in minutes or hours or days or months but in years or even decades. Ditto sludge and varnish. Humans are an impatient lot so to see the benefit of a truly superior product you may have to wait a very long time. Most will get bored first and trade before they reap the benefit.   Humans are not companionate creatures when it comes to those we do not know. We don't care what happens to the second or third owner as long as it doesn't happen to us or someone we know and actually like.   Sad commentary on humans but it is what it is. That thus, then, there is no advantage...to or for you if the above paragraphs adequately describe you.    BUT if you are a buy and hold type and patient enough to reap the rewards of your labors then that thing that is happening that you haven't yet seen, but will; can be abated by such products. Seals harden and leak with time and lots of it. Rings stick after thousands of miles of a slowly building plaque of varnish.    Then there is this. This didn't happen over night and this poor fellow knew when he removed the cover and not one second before.   Not "aware' isn't the same thing as "isn't happening".        The above was typical of the Ford 361 and 391 bus motors on Bulk Pennzoil Mineral Oil products on 3K mile OCI's at about 60K miles back in the 60's and 70's at the Anamosa School District when my Uncle took over their maintenance program.    This is Pepper at @ 165K on 5K OCI's using Group IV/V Full Synthetics.      HM oils will help the first but not the second.    Then again if one used..... ah, ya know.....
    • Thanks for coming back with an update.
    • Awesome you got it sorted! That's a new potential issue I'll have to mark in my book of issues. Thanks for the feedback.
