Price includes the OEM LTZ housings, ballasts, Osram CBB bulbs, and relay harness. Once I get them out I'm going to finish plastic welding the extensions onto the stock bulb caps. These have FAR exceeded my expectations.....but I'm trading the truck so I'm putting the factory halogen housings back in.
NHK G5-R projectors swapped in with brackets from Phil at fastheadlights.
High beams are halogen with the HIR bulbs modded and installed
Ballasts are Morimoto 35watt, relay harness is also morimoto.
Price everything out if y'all like. Not too bad of a price. CBB bulbs alone are $100+
Asking $700 shipped
Edited by Jaycreek7908
  • 5 months later...
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
