2016 Silverado LT
I recently purchased this item: https://www.amazon.com/gp/product/B06WGN7WRY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
(OEM NEW Keyless Entry System Transmitter 2017 Buick Chevrolet GMC 23473339)
I took it to my dealer once, and they told me $250 to program it.  I took it another time, and they said it won't work with my truck.
Could any of you tell me
a. Will this work with my truck?
b. If so, how can I teach my dealer how to do this?
It might. Its made for the 17s and later but it's been successfully programmed on late build date 16s. When talking to the dealer its all because of the BCM. I have not had a problem with 17s and later. It's probably why they came back and said no. You could see if you can find someone that can try and program it for you.
Sent from my SM-G975U1 using Tapatalk
2017-2018 and 2019 LD old body.  Doesn't fit 2014-2016.
The way its programed to the truck, nobody outside a dealership can do it.  The ID card that comes with it has to have a picture of it sent right to GM's programming department, along with all the dealership's info and your VIN in order to authorize the programming, and then they send back a file that the dealer uses to install the re-programming vis GM SPS.
Also, the $250 they quoted you is a rip.
Edited by newdude
Not true. Repair shops can as long as they have the proper authorization and equipment. Especially in areas like mine where there are not many dealers.
OK, it sounds like this thing I have will work for some 16s and not others.  Thus, I have these questions
1. How do I determine if my 16 is one of the ones where it will work?  Do y'all know a smart tech with whom I could share my VIN?
2. Are there any number-keypads that would definitely work with my truck?
Not sure but I think that the keypad only works on 2017 and up but here’s what I found while getting my keypad installed.
I asked the dealer where I bought the truck to get it and program it and asked about total price. Quote was $260.
Went to the local Buick dealer and asked – quote was $350.
Went to a smaller dealer about 15 miles from home. Total installed cost $176.
The service manager at the smaller dealer was not sure how to program the keypad – said that he would get back to me in a couple of days.
When he called back, told me that he called corporate about the install. Then said that there was a factory rep who would come to the dealership and program the thing for $42.40 including tax. Cost for keypad itself - $125 plus $7.50 tax
To me, it appeared that the first two service managers were pulling the cost for programming out of the air.
It doesn’t hurt to shop around for cost of install.
Rather than having the thing stuck to the door, I asked for it not to be installed but only programmed. In this way, I could experiment with various locations. Finally put it on the lower left side of the windshield. Works OK in that location.
- No way of knowing without having a dealer send the picture of the key code card, their dealer code and VIN to try and get the programming authorized.
- None from GM will work definitely.
Edited by newdude
On 10/30/2020 at 10:15 AM, ~~AAJakeleg said:
@Tim McMullen Would you mind sharing the name of the smaller dealer who actually got it done for you?  I'd like to call them and follow that procedure.  I don't live in a big area, so I don't have any more options.
Reminder for that contact info @Tim McMullen
1. I have the keypad in my hands.  Do you know any dealers I could call who might work with me to do this?
2. Are you aware of any non-GM keypads?
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
