Hey guys, I am curious (might be a stupid question but I’m new to adding parts to a truck and all that. Super green horn when it comes to this stuff so TIA) I found a guy selling the running boards off a 2020 AT4 and I was going to purchase them for my 2020 SLT. Both trucks are Crew Cab would they fit? Follow up question. The guy said that they are directly off the AT4 and they are the automatic fold down running boards. He said that there is no electric lines that need to be ran to hook them up for my truck. Is this true or is he lying? Thank y’all.
I have a crew cab AT4 and those are the stock running boards.  Yes they will fit your truck no problem, but they are not auto fold down.  They stay down all the time.
The guy is trying to sell them to me for $300 should I try and talk them down since they they are fixed running boards?
Brand new those are $850 from the GMC accessories website. Never hurts to try and get the asking price down but it's Not a bad price drop if they are in great shape and you're dead set on getting some factory steps to have some piece of mind knowing they fit. Or browse Amazon/eBay for different styles that fit for a little more of a custom touch. Price ranges from around 150 to over 1200 for auto fold styles. If you go that route, read read read the reviews.
Yes, he's lying and because of that I'd be very leery of dealing with him. As stated earlier those are GM fixed running boards (I have the chrome version).
That said, if you like that style $300 is a good price. They are a nice & sturdy running board.
These are hard times. It's your money and many people aren't buying things right now. It never hurts to ask and try to get it for a cheaper price.  Good luck with "bargaining" and your purchase!! Those are nice boards!
