[email protected] Posted November 12, 2020 Posted November 12, 2020 Ok so I’ve noticed a strange knock sound coming from engine during cold starts not really cold temp but after the truck sits for awhile 3 or 4 hours. After start you have the high idle kick in for a bit then once the idle drops back to 500 rpm or so I can here an intermittent knock or series of knocks coming from lower in the engine. You can also hear some sort of actuator ticking away that’s not what I’m talking about. If you drive the truck for a while and stop you can’t hear the sound anymore until the next cold start. the engine is a 5.3 with 3.500 kilometres on it IMG_5447.MOV
aragrev7 Posted November 12, 2020 Posted November 12, 2020 I have this exact same thing. Same mileage. AT4 5.3L. I couldn’t watch the video, won’t open, but it’s definitely the same as my issue. Dealership told me it “may” be the fuel pump. In their words, the sound “could be” within tolerance, but GM is not willing to investigate unless it gets worse because chasing a sound could be very expensive and labour intensive. “You have a lot of warranty left, I wouldn’t worry about it yet.” Apparently there is some sort of bulletin that suggests the sound “could” be normal. It’s loud and irregular, and more and more noticeable when as the weather gets colder. Sent from my iPhone using Tapatalk Pro
[email protected] Posted November 12, 2020 Author Posted November 12, 2020 Thanks for the reply . IMG_5447.MOV Not sure why the video won’t open but I’ll try uploading again
[email protected] Posted November 12, 2020 Author Posted November 12, 2020 Ok guess that didn’t work lol
Bob2C Posted November 12, 2020 Posted November 12, 2020 Ok so I’ve noticed a strange knock sound coming from engine during cold starts not really cold temp but after the truck sits for awhile 3 or 4 hours. After start you have the high idle kick in for a bit then once the idle drops back to 500 rpm or so I can here an intermittent knock or series of knocks coming from lower in the engine. You can also hear some sort of actuator ticking away that’s not what I’m talking about. If you drive the truck for a while and stop you can’t hear the sound anymore until the next cold start. the engine is a 5.3 with 3.500 kilometres on it IMG_5447.MOVHave the same thing on my 18 5.3. Been like that since day one. 30k miles later it’s not any worse. Goes away when warmed up. Normal GM clunking/knocking IMOSent from my iPhone using Tapatalk
aragrev7 Posted November 12, 2020 Posted November 12, 2020 Have the same thing on my 18 5.3. Been like that since day one. 30k miles later it’s not any worse. Goes away when warmed up. Normal GM clunking/knocking IMO Sent from my iPhone using Tapatalk That’s a bit better to hear. Though for longevity of parts (I tend to keep my vehicles for 8-10 years) loud clunking tells me I’m going to have some significant wear/damage by that point, because let’s face it, loud clunking/ticking means parts contacting harder together. My main worry was my in-law’s Ford had the same issue that they finally dealt with 3 weeks ago. Dealer ended up dropping him a new engine with only 4 weeks left on warranty. Sent from my iPhone using Tapatalk Pro
Register a new accountSign in
