Don't mean to be a dick, but on the first page alone, there are 4 stock biggest tire size threads going on. lets try to read first, then ask a question.
Easier to ask than do the research. Common.
  • Like 3
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
