Hey guys,
so I’ve seen a few thread on this forum and social media About people swapping over to the hd front end. Bumper and grill..
I’ve messaged a member here who’s done it and can’t get a reply. So who can help..?
iv sourced a compete hd bumper and a hd grill.
i understand you have to get the filler pieces and brackets, trim down the black fender trim and slot the 1500 mounting brackets to allow the bumper to drop down a bit. I’ve also seen possibly shimming the mounting brackets out 1/8”
However, nobody addresses the towhooks. From what I’ve seen they don’t line up. Which makes sense however is there A solution??
second, what other problems could I find? I will be roughly $2-2500 deep into parts.
not worried about paint, or the labor. I am capable of both.
Any updates? Im in the same boat , although ive heard that the stock bumper brackets work if you drop them about 1/2” and redrill im yet to verify but 3 guys that did it said they used the stock bracket and lowered it , 2 other guys said buy the hd bracket and weld lower , im hearing possibly 2500 bumper guides maybe needed
Edited by 15GMCALLTERRIAN
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
