I would go to the service department of my dealership and ask to speak with someone knowledgeable on the subject.   If they can't confidently explain the operation of your two battery system, then phone GM customer support to find the answer and to report on your untrained local service technicians!   In my situation, I'd simply need to phone my salesman and he'd find the answers.  He may not be a mechanic but he knows how to keep a loyal client!  I've owned this truck for 5 years and I still expect (and receive) this level of service.
To confirm what George said I checked the power lead in the 7 pin with and without the 30 amp connection off the secondary battery being connected.  Just like was described, the 30 amp lug off the secondary battery supplies the power to the camper with the battery isolated with the truck off.  Thanks everybody.  I think this is solved.
Here is the fuse layout on the starter battery.  The 400 amp goes to the starter.  The 250 is the alternator.  The others disappear into the wire harness
So the 100 amp that is in that box I would assume goes to the other battery..
Sent from my Moto Z (2) using Tapatalk
I thought it operated as such:
Truck off = batteries isolated
Truck on = batteries isolated
Truck running = batteries connected
100A fuse at isolator is so alternator can charge second battery (when truck running)
30A fuse at isolator goes to 12V+ of 7way trailer plug.
I think this means you can drain your second battery with a camper and still start your truck with primary battery.
I may be wrong, hoping someone else can back this claim.
...i did a little experimenting when wiring in my battery maintainer quick connects (one for each battery). My memory is foggy on those results.
That all sounds good to me....I want that setup now tho...mine will basically be the same way tho it has a voltage sense switch to turn relay on and off ....
Now u just have to put one of these in so u know where ur battery level is
I'm just guessing now because the wiring harness is all a big bundle. But it would make sense that the 100A is the 100A at the other end at the secondary battery.  Also, the 175A probably goes to the main fuse box.  There's a heavy gauge line that hooks up there.
Slight topic hijack here.  I have not had dual batteries on my previous trucks, but I plan to order them on a 3500HD next month, primarily for truck starting/operating redundancy when remote camping.  (My camper has its own battery system.)  It looks as though the isolator, fuses, and battery wire gage as delivered by GM are not designed to allow you to start from the aux battery if the main battery is dead.  What do you do in that case?  Physically swap the aux battery to the main position?  Use jumper cables from one battery to the other?
If you’re not pulling from the truck battery you shouldn’t have to worry.  If so, it draws from the secondary battery and leaves the primary fully charged
Edited by Bob 3500HD
    250.3k
    DjmFingerstylePlayer
  • Who's Online   4 Members, 1 Anonymous, 710 Guests (See full list)
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
    • Chris 21 I appreciate your constructive response. !!  😉😉😉   The 6.6 is gas.  Correct me if I’m wrong but by recalibrating the speedo you’re correcting the shift points of the transmission on these trucks.?.
    • That is a huge misconception.     Bigger does not always equal safer.  Modifying does not make it safer either, with exceptions.   Think of this.  Your truck in stock form is capable of emergency maneuvers, proper stopping distances, its handling is designed around the factory wheel/tire packages, etc.   37s and a lift?  Now you've affected your braking distances, handling and ride control.  You've raised your center of gravity higher.  Your front visibility is now obstructed more than stock, same for your rear.  Does it look cooler?  Yes.  Does it now work as good as it did from factory on road?  NO.       As for my mention of exceptions?  Say you had a sedan or crossover.  They typically come with all season tires.  If you swap out for a performance all season or a summer tire, you improve your car by lowering its stopping distance (better braking because of traction) and improve the handling (regular and emergency) of the vehicle.  That is an actually improving modification.  My old 2019 LD 1500, I ran UHP all season tires on 20in wheels in a factory offered size.  It improved all aspects of how it drove over the Duratracs it came with from the factory in the stock 18" tire.
