do 2018 Silverado dash board computers need to be adjusted when you put bigger wheels & tires on the vehicle,  my computer fuel mileage calculator is really messed up reading it but I am sure that I am getting better mileage than the computer is showing me? I realize that it will be effected but I did not think it would go up & down so much?
Did you put bigger tires on your truck? If so, they rotate fewer times per mile making your computer think you've gone less miles. This will lower the speedo reading and show lower mpg.
 I used the hypertech speedometer corrector to fix mine after I put 35s on. Going to 35s was about a 10% difference on the speedo.
Yeah definitely use a hand held tuner.
Not gonna recommend one cause the last time I recommended a product on here I got a time out. [emoji38]
Sent from my SM-N975U using Tapatalk
I've addressed with the poster by PM but everyone else:
Product recommendations aren't prohibited on this site, even if the product is not a current sponsor. Only blatant advertising by someone who has a monetary connection to the product or spamming by PMs, these actions may cause info to be removed. In any case members will receive an explanation of the issue.
I feel you may have been caught up in our site software issues several weeks back and the info was simply lost. Others suffered the similar fate.
So product recommendations = good
Selling a product without paying your fair share to the site for advertising = bad
There is a product review section, if anyone wants to let us know about something they've tried out and believes the rest of us should have it too
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 449 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
