I'm looking for a used grille (GM 23207684), either to purchase or swap.  I have the 2019 LTZ/Z71 grille.  I've had success swapping rims before, perhaps someone is interested in swapping grilles, or has one they'd be interested in selling for a reasonable price?  local used auto parts do not have any and my understanding is the grille is interchangeable from 2016 through 2019.  New prices are a bit too steep to justify the expense.  I'm near Fredericksburg, VA.  Thx.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
