Howdy - trying to remove the splash guards front and rear and it looks like the rear wheel splash guards are attached with a mix of Torx bolts (blue in photo) & what I think are pop rivets (red in photo). From what I'm finding, I'm probably going to have to use a drill or something to remove the pop rivets.
Is this the correct way to remove these pop rivets? Just kinda confused that I have to destroy the rivets to get the splash guard off versus just everything being Torx so I can take them on & off easily in the future. Sorry for such a goofy question - thanks.
Pop rivets need to be drilled out.  That said, why are you pulling em?  It's my understanding they protect the vehicle quite a bit
@Rob Mugs Partly for looks & mostly for taking the truck off road and getting into situations where these will get torn off. Thanks for your input. Just kinda weird (to me at least) that they were riveted on to begin with.
So, I just went out to my 2020 to take a look and there are no rivets.  Perhaps something done differently on the WT without wheel well liners?  Mine are body pins and screws
Either way though... just take a small drill bit (about the size of the hole in the rivet) and drill it out.  It'll all pop off in a few seconds
Take the screws out and see if it comes off without drilling the rivet.
Perhaps the rivet is to fasten a 'spacer' on the back of the splashguard when there are no wheelwell liners, and isn't fastened to fender.
Just a guess, but costs nothing to try just the screws first.
I had to replace one of my splash guards. Its been said already, best way to get the rivet off is to drill out the rivet head, and the rest will slide out. New splash guards from the dealer come with new rivets which you would need a rivet gun to install.
I'm thinking about replacing my splash guards with the regular mud guards. I have a little bit of rub, even with the mud flap brackets removed. The regular mud guards seem to have a bit more room.
@Trza & @redwngr & @Rob Mugs
Thanks for your help. Turns out @redwngr was correct in that the riveted portion was just wrapping around the metal of the wheelwell & there are no holes in the metal that the rivets go through. Basically the metal is sandwhiched between the splash guard and another small piece of plastic on the inside of the wheelwell.  I was able to remove the Torx screws and then slide the splash guard off with the rivets still attached. However, most people probably want to drill those rivets out because it's a very tight fit and I had to slide grit-covered plastic over the painted metal which most people are NOT going to be cool with doing as there's a potential to scratch some clear coat - not too much of a concern for me though. Thanks for your help & entertaining my goofy entry-level question.
  • 2 years later...
Did you ever find out the size of those pop rivets? I may need a whole new right front splashguard as the mounting hole is cracked open. Even if put I new rivet on it may slide back off.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,213 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
